newfie09xtx
- Jul 13, 2011
- Corner Brook, NL
- 2016 Polaris Switchback 800 Pro S
hyprst said:radianguy said:14.5 rollers
8CR-17624-00-00
YPY SPRING
90501-581L5-00
Is that the right part # for the rollers? I come up with 8FG-17624-00-00.
RadianGuy has the right numbers. He just installed them in my nytro.
radianguy
- Jan 1, 2007
The difference between the 8CR and the 8FG is the material of the rollers, one is duralon the other is vespel. The 8CR's are a bit cheaper.newfie09xtx said:hyprst said:radianguy said:14.5 rollers
8CR-17624-00-00
YPY SPRING
90501-581L5-00
radianguy said:The difference between the 8CR and the 8FG is the material of the rollers, one is duralon the other is vespel. The 8CR's are a bit cheaper.newfie09xtx said:hyprst said:radianguy said:14.5 rollers
8CR-17624-00-00
YPY SPRING
90501-581L5-00
Thank you for the clarification! Which material has a longer life span?
yukon yamaha
- Jan 30, 2008
- WHITEHORSE, YUKON CANADA
- 2008 nytro custom! 2014 viper custom
There is also an 8mm and 9mm diameter roller , keep an eye out for that too
extreman1
roller change
if u change to the 14.5 gram rollers, what effect would changing the helix to a 51/43 have??
radianguy
- Jan 1, 2007
I'm not sure, I took a set of duralon rollers out of my 2000 700 venture to try in my XTX, the venture has just over 20,000 km so I say they last a good while, lol.hyprst said:radianguy said:The difference between the 8CR and the 8FG is the material of the rollers, one is duralon the other is vespel. The 8CR's are a bit cheaper.newfie09xtx said:hyprst said:radianguy said:14.5 rollers
8CR-17624-00-00
YPY SPRING
90501-581L5-00
I have a new set to put in my XTX, I will be putting the used ones back in the 700 venture.
newfie09xtx
- Jul 13, 2011
- Corner Brook, NL
radianguy said:I'm not sure, I took a set of duralon rollers out of my 2000 700 venture to try in my XTX, the venture has just over 20,000 km so I say they last a good while, lol.hyprst said:radianguy said:The difference between the 8CR and the 8FG is the material of the rollers, one is duralon the other is vespel. The 8CR's are a bit cheaper.newfie09xtx said:hyprst said:radianguy said:14.5 rollers
8CR-17624-00-00
YPY SPRING
90501-581L5-00
Radianguy, your Mods are taking up too much room! LOL How'd ya get them to fit??
carpenter
- Jan 6, 2005
8fg is the correct rollers
toyota4runner
- Jan 23, 2012
- Manitoba
- '09 FX Nytro
There's a good chart explaining the roller part numbers and sizes in the technical pages of TY Home at the top left of the page or TotallyYamaha.com. Go to technical pages, snowmobile tech, clutches and jetting, and then down to rivets and rollers
radianguy
- Jan 1, 2007
Removed all of the comma's! LOLnewfie09xtx said:Radianguy, your Mods are taking up too much room! LOL How'd ya get them to fit??![]()
