wantboost
Looking for a starting baseline for my clutch set up.this is a 03 rx1 cpr frt mount 2560 turb gonna set it at around 18 psi and this will be used for 660 drag race only.136 full chisel track so traction ain't a problem and this is on ice.I have new stm weights 55gram base and a shockwave helix.my ? Is how should I set the weights up for a starting point and anyone know how many turns on the shockwave to start can't remeber the primary and secondary spring color off hand but can check if needed tomorrow.thanks
Stigapex
Suspended
I would have started with two tungsten om heel, 6 gram in the middle and one or two gram at the tip . primary spring around 45/111. I dont know about the shockwave but around 54-56 degrees starting if its a progressive.
tube
run 66g polaris weights and pins grind the tips just a but so they clear with a yamaha orange primary spring and 3 washers cut 30 thou. off the primary sheaves run a multi angle shock wave helix with 60 thou. cut off the end 1 turn out and a black yellow spring and hang on best clutch kit ever this apex rocks runs 10800-11000 depending on conditions ----2006 Apex GT
tube
- 11K
