What belt Dano?
Dano74
- Nov 16, 2014
- 2008 Yamaha nytro rtx
8dn.....guess I better check the drivers and the gears hopefully I can do it with out pulling the cover.What belt Dano?
Dano74
- Nov 16, 2014
I was standing in the dealership earlier this year when they un-boxed a new 17 xtx that had already been wrecked....apparently they dropped it at the factory and decided to box it and ship it anyways. The whole right side of it was scratched up and the tunnel was bent and twisted but the crate was in perfect condition! Another xtx came with mountain skis instead of tuner 3's ( wish mine did) so quality control seems to be an issue sometimes.8dn.....guess I better check the drivers and the gears hopefully I can do it with out pulling the cover.
Are you at 6-1 wrap on secondary? If you look real close at your pic the belt is actually 1/4in from top or better. That's not bad. Mine wth gearing never gets up that far even at over 100mph. So doubt gearing or drivers.
Dano74
- Nov 16, 2014
I've tried 3-3 6-1 6-2 and everything in between gonnna try a different belt tonightAre you at 6-1 wrap on secondary? If you look real close at your pic the belt is actually 1/4in from top or better. That's not bad. Mine wth gearing never gets up that far even at over 100mph. So doubt gearing or drivers.
