clutching help?
petetown
Melville,SK
Canada
2011 nytro xtx boooooosted!!!
Hi there im running a turbo at low elevation 10lbs boost on my xtx with a 2.25 paddle im having some clutching troubles first off I had purchased a clutch kit from ulmer to work with my exhaust and filter setup im not sure where to go with springs on the turbo setup currently I have a primary spring that looks to be marked orange yellow orange which I could not find info on also the secondary spring has 2 white stripes side by side im an aggressive rider mostly off the trails wondering if anyone can point me in the right direction as to what springs to run im looking to increase engagement as well and im not sure what would be best to run in the secondary any help will be appreciated thanks in advance.
