Accentstripe1
Hey guys,
Finally wrapping up my sled for the hillclimbs this year and was wondering what type of set up as far as clutching I should use. This is a front mount turbo running 15lbs on average with a 144 1.5 crossover track with no studs. Im also running a msd launch master set at 4500 so my clutch would engage at 5000. I dropped a lot weight from the sled and I weigh 185.
The setup I had last year was for a 136 1.25 track with a ton of studs.
Primary: 14.5 rollers, yamaha white/silver/white spring, 71 gram supertips
Secondary: yamaha silver spring, hartman helix (cant remember the degree but marked 05GN)
23/39 gears
Any help would be greatly appreciated
23/39 gears
Accentstripe1
TTT
