clutching info and questions
DAGE
where the snows at
Other
06 Attak
I was out the other morning for a ride and the groomer just passed so it was nice and hard and I was able to hit 121 mph on the DM from my 144" stretched Attak here are the specs if anyone is interested, I will say this I don't know what it is but whenever someone gave me clutching tips I'd always have to throw alot more weight at the sled to get it to the proper RPM's so if anyone tries this don't be surprised if it dosn't work.....
DnF weights
1 bolt 4 washers in heel
1 bolt 1 washer mid
1 bolt 1 washer O/D
1 bolt 2 washers tip (this bolt is 4g not 3.2g like the others)
stock helix shimmed @ 70 degrees
white spring in sec.
HC black in prim.
10400rpm out of the hole and 10800rpm full shiftout
now I have a set of 2speeds I want to try and want a base setpoint if anyone has one....
Kyle
