red rider
- Oct 14, 2005
Can anybody give some advice on what is reqired to clutch using this belt? I am losing about 1000 rpm on top end. I believe it is due to the increased length. If I shim the secondary will that be fix my lost rpm?
Thanks Guys
Thanks Guys
Len Todd
Seems like the Rs would go up with a loose belt (i.e. slipping belt). But if it is longer, you need to set the deflection. You may be able to compensate by adjusting Belt Height in the Secondary. But, this adjustment is limited. The only other adjustment you have for this is Center-to-Center.
Is the belt width the same as OEM?
BADSLED
- May 13, 2004
- Syracuse, NY
- 2012 Nytro MC Xpress 270
2011 Apex SE
2021 Sidewinder LTX SE - SOLD
It's a softer compound belt that's why you are seeing less RPM..
red rider
- Oct 14, 2005
It's that xsx belt that snowtech was promtoing. Any idea's as how to clutch for it?
- 11K
