chadman
What are the pros and cons of these tracks and which one is an all around track and there will be studs in the one that I choose? Who has the best price? Thanks
Chad
Chad
big_red1a
Track
cobra with studs outperforms in every condition
heelingcowboy1
X2 on that!!! Cobra is head and shoulders above the ripsaw PERIOD!!
chadman
How is the cobra as far as durability vs ripsaw?
ahicks
If you need studs, I'd go with a Predator. The studs required to do any good on the Cobra are going to be something like 1.4's. That's a lot of length/weight, with increased potential for trouble...
The Predator will run right with a Cobra in loose conditions, and studded, should do fine on hardpack. I love the Cobra, I just believe there's a better solution if you need studs.... FWIW
I think the Predators are on sale at tracksusa....
The Ripsaw is a POS.....
POB88
The ripsaw is a great track just not on a apex.
I went with the cobra and all i can say is
LOL!!!
I do think the predator would be just as good.
chadman
You can't get the predator in a 136x1.25. That is what I wanted to get but, I can't find one fully clipped. Is the six pitch the same as the predator?
Just be aware that a Cobra will scrub a few mph off of your top end! When I found this happening I talked to Allen Ulmer about it and he told me that he found the same thing. I took mine out and went with a Predator and am very satisified and the speed came right back. This was on a RX and an Apex with the same results.
langow
chadman said:How is the cobra as far as durability vs ripsaw?
I've got 3800 miles on mine. It's still in great shape. After a close inspection I could only find 1 lug with a slight tear in it, otherwise it looks like new.
kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
I hace had them all and the predator or cobra is the best. The cobra is better at braking but loses some speed (not a lot).
I always run 144 studs down the middle on all tracks and the cobra is my favorite so far.
When I talk predator I had the 1.25" version.
Predator will definitly be cheaper if you can find one you want.
langow
kinger said:I hace had them all and the predator or cobra is the best. The cobra is better at braking but loses some speed (not a lot).
IS there a specific stud you prefer with the Cobra Kinger? 1.450"? or?
kinger
- Jan 17, 2005
- Clear Lake, IA
Mine are woodies 1.45"
I dont usually have a preference on studs.
SledFreak
- Feb 7, 2005
- Ontario. Canada
rxwarrior said:Just be aware that a Cobra will scrub a few mph off of your top end! When I found this happening I talked to Allen Ulmer about it and he told me that he found the same thing. I took mine out and went with a Predator and am very satisified and the speed came right back. This was on a RX and an Apex with the same results.
I agree, I lost 4mph on top and slowed acceleration once you Reach 95+ mph after installing the Cobra. The ripsaw pulled harder up top.
Nick1945
I went with the 1 1/4" Predator, fully clipped for this season, and, 144 1.325 gold diggers up the middle.
KevinS
I decided to go with a 1 1/2" ripsaw this year. I was looking around for a while and was torn between a predator and this taller ripsaw. I got the ripsaw for a pretty low price so I decided to give it a try.
