big_red1a
if you use the 1.450 studs keep an eye on your track tension. To much balloning and you will end up with damaged exhaust.
chadman
whare can I get a 1.25 x 136 predator fully clipped that is new?
SARGENT
what is the difference in the corners. is the cobra loose in the corners compared to ripsaw
langow
SARGENT said:what is the difference in the corners. is the cobra loose in the corners compared to ripsaw
You can definitely get the back end to kick out a little more with the Cobra, but I wouldn't call it loose.
SledFreak
- Feb 7, 2005
- Ontario. Canada
langow said:SARGENT said:what is the difference in the corners. is the cobra loose in the corners compared to ripsaw
I agree, it's not much difference then the ripsaw, as far as, side bite is concerned. You want loose, get a 1" hacksaw....
kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
SledFreak said:langow said:SARGENT said:what is the difference in the corners. is the cobra loose in the corners compared to ripsaw
I agree, it's not much difference then the ripsaw as far as side bite is cioncerned. You want loose, get a 1" hacksaw....
X2! Good description of each track I found the exact same differences
