Code 11?
JacobZ
Age
32
Yamaha Phazer 2007
My Phazer is flashing a code 11. What is it?
Check the list of Phazer fault codes at the top of this Phazer General Talk Forum. Code 11 says it not receiving proper cylinder identification signal. With a list of possible faults, such as open harness, sensor kaput and or ecu problem. Apparently it's not getting a signal.
Fogot to ask if you have the updated ground block done?
