robert327
hi guys just poped over from apex fourm to help my brother he has a 2010 phaser rtx and its showing code 34 i checked code description but can anybody be a little more precise
- Nov 1, 2009
- Winnipeg, Manitoba
- 2009 Phazer RTX
Double check that the ignition coil is properly plugged in. Then if it is, swap the coils around to see if the problem moves to code 33. If it does I suspect the coil has gone bad.
If the code remains 34 I would start looking for an open or short circuit.
Between cylinder-#2 ignition coil coupler and ECU coupler.
Gray/Red – Gray/Red
Red/White – Red/White
Gray/Red – Gray/Red
robert327
ok thanks
Ruggybuggy
- Sep 1, 2013
- Kenora, NWOnt, Canada
- 2007 Phazer FX 144
If you have to buy a new coil don't cheap out and buy an aftermarket one. The coil on the Phazer looks very similar to the coils on my FZ1 and know someone who tried to use a cheap coil on his FZ1 and it blew the ECM, took out the driver.
robert327
thats good to know thanks
- 6K
