code 46 questions
stik87
So today I'm up riding and the starter solenoid went out so was just jumping it after every stop until the code 46 starting popping up and hand warmers went out. I had to get a jump start from there every time we stopped until we got to a spot where I could get a battery charger on it for a while and I still had to jump the solenoid but it started without a jumpstart. What could be causing this issue? I wouldn't think it'd be the solenoid alone would it?
up in the noise on the sled on the left side looking in from the front there is a bank of relays, switch the third one with the second one i do believe it is this should fix your problem. go invest in sealed relays well worth it I'm after swapping this relay twice now finally went and ordered a sealed relay to fix the problem.
