JesseD32
- Dec 10, 2020
- NY
- 2011 Nytro XTX
So I am waiting on a new starter solenoid(by the battery) so I’ve been starting it with a screwdriver. I recently had to replace the starter, and instead of waiting for the new solenoid I figured I’d try the old one just to see if it was actually junk. When installed it did nothing, when I tried to jump the terminals it just turned over and wouldn’t fire and then said code 43. So I put my OTHER old shitty one in it and I jumped it and it ran. BUT when I’m on the trails and try to hammer on it at all it bogs down and I can only get about 50-60 mph. If I slowly give it more and more gas it doesn’t big down until about 1/2-3/4 throttle. No codes...Will my new solenoid fix this or is it a different problem? Started doing it a little last year before my solenoid died, was just wondering if maybe the voltage wasn’t good enough for the injectors or fuel pump or something....thanks!!
was it green around the fuses?
JesseD32
- Dec 10, 2020
- NY
- 2011 Nytro XTX
There might’ve been a touch of green but nothing crazy, I was just wondering if that would effect the throttle/ bog that it has....I should have a new solenoid tomorrow but wasn’t sure if it was the cause of my sled running like crap past 1/2 throttle
JesseD32
- Dec 10, 2020
- NY
- 2011 Nytro XTX
Wasn’t sure if the solenoid will fix it or if maybe it’s the crankshaft position sensor is starting to fail but not throwing a code yet.
yam429
- Jan 18, 2009
- Saint Michael, MN
- 2009 Nytro XTX, 2010 Vector LTX, 1981 SRX 440, 1989 Inviter, 1991 Snosport, 2004 Snowhawk
- Saint Michael
Has the throttle position sensor been messed with?
- 19K
