Ok. And then what, tie into that wire and run it to the handlebar warmer switch?Then use the black wire at the pump as your ground source.
What I mean is when testing voltage at the pump plug you should use that ground at that plug,Ok. And then what, tie into that wire and run it to the handlebar warmer switch?
I haven't looked at the starter solenoid plug, would have to find that. But the starter will crank, just no fuel pump operation and I know the fuel pump is ok now. I'm getting a code 81/heated grip flashing, that is the only code flashing.What I mean is when testing voltage at the pump plug you should use that ground at that plug,
Also a good idea to have a bit of amperage load.
Have you inspected the plug at the starter solenoid?
I think the Phazers pull power there for the fuel injection like most other Yamaha models.
What error codes are on display?
