shawnburt66
- Feb 27, 2023
- Bunyan's Cove, Newfoundland
- 2012 rs Venture
Went for a ride the other day and the warning light came, thought it was low on gas at first. Made it home safely but sled wouldn’t restart and engine symbol was showing in dash as well as code 43. It diagnostic mode item 62 showed two faults. Changed a relay located behind left footwell to an updated version which cleared one fault but sled wouldn’t restart not restart. Started checking fuses and noticing some corrosion, craned them up a bit and applied dielectric grease. Problem fuse was located under breather box and is for fuel injection. After cleaning up this the fault cleared. Sled appears to be working fine now.
