cold air intake ?
I got there intake .... Seems to have very good low and mid range maybe gained 1 to 2 mph on top ... anyways it works pretty good i think
get some fibre stuff to go over the vents. Helps with snow getting through, and looks Good!!
Ulmer Racing is working on a new intake kit for the FX Nytro. Better fit, better finish, and hopefully the same performance as our current air filter kit!
PoliticalMachine said:
Any details on the kit Allen? Are you still using K&N air filters? Any release dates in mind?
Large oval shaped K&N filter which will have all three throttle bodies feeding from it. Aluminum "end caps" and the "front" aluminum end cap will have mounts welded onto it which will mount it to the stock air box location on the subframe.
Are you awaiting dnyo test results to decide if your gonna produce kits for sale? I'm in the market to buy an air filter setup so hopefully everything works out. Keep us posted on the progress.
Andrew
Do you have a release date?? Sounds pretty cool!!!
I need to do some comparison testing on our chassis dyno yet as well as waiting for final pricing on the prefilter and the aluminum end plates. I will post some pictures when I have a production kit finished.
