cold air intake,
hopewell64
northern n.m.
just put in a yoshi, rs3 slip on on my mtx. do i need a cold air intake or is there some type of mod that can be done to the stock intake. also would a programmer be needed, if so which one. Any one try that box thats on ebay for 40 bucks, its some kind of resistor type thingy. i ride from 8000 ft to 12000 ft if that makes any difference , thanks
Not much to do to the intake and a fuel programmer is not needed. The best thing to do is change the clutching. With the stock set up you will see a big drop in RPMs when riding and climbing above 10k ft.
8BF weights w/o rivets, 14.5 rollers, the stock MTX primary spring and stock secondary settings.
thanks for the info rideblue. where can i get these parts you mentioned. I am pretty new to this sledding thing. but not afraid to gain a little better performance.
