canadianhunter
My two are NEW and Idle at 1400, never touch the idle adj.
RSVECTORFREAK
- Oct 28, 2004
- Chassell Michigan
- 2005 RS Vector ER
az99 said:Mine has done that from day 1. It has to run pretty long after the light goes out before it will take any throttle.
I will bet that RSVectorFreak 's sled does not have this glitch.![]()
As of matter of fact it doesn't. I have flo commanders installed so it's always running with the carbs synched perfectly and running mint!
yammie3687
- Dec 14, 2005
Have you tried changing the spark plugs?
QCRider
- Feb 27, 2004
- Seacoast Region, New Hampshire
- www.myspace.com
yammie3687 said:Have you tried changing the spark plugs?
A really good idea! In fact, no I have not, but I certainly will. It seems to be clearing up a bit after a few minutes of running Sea Foam through it. I will change the plugs now and see what happens.
QCRider
- Feb 27, 2004
- www.myspace.com
Can anybody tell me what plugs a Stock Vector should run? I am at work without my manual and would like to buy some today.
STORM-CHASER
QCRider said:Can anybody tell me what plugs a Stock Vector should run? I am at work without my manual and would like to buy some today.
NGK R CR8E .07-.98 mm Gap
hondo
Check your plugs, if they are black and have a wet fouled look, this will be a good indication that you have some plugged pilot jets.
I had 2 jets that were clogged from summer storage.
My dealer cleaned and synchronized the carbs when I had it in for the updates.
Concur with the response: Idle should be set at 1400 rpms when everything is clean.
Hope this helps!
Hope this helps!
