06rsvectorer said:My Vector Started at -40 with no problem, You could tell it was cold because it turned over alittle bit slower but she fired up with in 2 seconds. Old problem I had was the headlight and taillights would not turn on, I had to hit the highbeam switch a couple times for them to turn on.
No need to hit anything at all they will come on all by themselves in a few minutes. Have seen this with my Rx-1's dont know why they do this but they do.
LazyBastard
Bet you they'd fire right up easy with an 03 battery.BlgsRX-1mtn said:LB at that altitude; even the Apexes with 87 octane unleaded don't like to fire with -40 deg fuel.
culvert
Hey guys, New to this 4-stroke starting. Didnt get the owner manual when I bought my sled used.
What is the proper way to start these sleds and not foul the plugs?
kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
Full choke, start, slowly work choke back to off.
kinger said:Full choke, start, slowly work choke back to off.
Exactly how I do it for a cold start have had no problems. When the sled is warm give a little throttle while cranking over with no choke will start right away. If your sled is a EFI just turn the key and crank.
culvert
Thanks, guys.
Just wanted to make sure before I start fouling plugs. $15 a piece is not something I want to be going through.
So best is get sled started and then wait for the temp light to stop flashing before riding?
culvert said:Thanks, guys.
Even a bit longer make sure the sled is warm before riding for sure. Also make sure your track and ski's are not stuck to the ground will save your belt.
LazyBastard
It won't LET you ride before the temp light goes off.culvert said:Thanks, guys.
And whats this plug fouling thing you speak of?
culvert
I havent fouled any yet. Just others comments on TY that have fouled there plugs. Dont understand myself how you foul them?
I just want to make sure I run this new sled properly.
Convert
- Apr 14, 2003
- Lakeville & Nevis, MinNoSnowta
10,000 miles NEVER fouled a plug.
LazyBastard
Damn Gramps, when did you get ahead of me?
BTW: I keep forgetting to grab the things I'm going to send you when I go up north. But rest assured, I will send you them.
