butches
- Jan 4, 2008
- McHenry, IL
- 2015 X-TX-SE MPI Turbo 180
2017 L-TX-LE Sidewinder
Hurricane Tuned 225/240/270
Thunder Clutching
12,000 miles as of 2/8/2022
Cool! Now where is that pic taken!
Between watersmeet and Kenton MI
Dang looks like I am going to have to take a drive for snow this week!Between watersmeet and Kenton MI
tapex_07
- Feb 15, 2009
'07 Apex RTX SC2 MPI 128x1
Another thing it could be is the "shift fork," if its worn from holding the gear in place it may not have the same tolerance to help hold the gear over onto the splines. Check for wear in the gear, bushing, actuator, detent position, both upper/lower bearings, chaincase fluid (burnt?), chain tension and any shavings on the magnets.
TrueBlue
About all you can do is try testing the actuator. Has chaincase been apart yet? Does it have the detent update? Should being a 15.
I am not aware of the detent update. What is this & what is involved. Is the 2 relays for the reverse solid state now.
grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
No solid state relays used on the viper. All the relays used in a viper excluding the two 5-pin reverse relays are 4-pin and can be installed if rotated 180 degrees. Because of the possible 180 degree rotation there is no set polarity orientation for the coil side of the mechanical relay. A solid state relay is polarity dependent so it would have to be installed in the same orientation every time which makes the chances of a replacement SSR very unlikely. The reverse relays have a set installed orientation due to it being a 5-pin relay so a replacement would be a possibility.
I've mocked up a pigtail conversion for the ISC and Fuel pump relay to accept a Yamaha SSR but haven't tested it yet. I'm also considering another possibility that may help with all relays not just the ISC and Fuel.
Here is Detent info. Like said yours should have it already.
http://ty4stroke.com/threads/tecbulletin-s2014-001-reverse-actuator-extension-update-kit.125952/
