jdp1under
- Oct 19, 2009
- CT, NO SNOWVILLE
- 2010 RS VECTOR GT LTX STOCK FOR NOW!
Well this year im doing a complete full oil change inlcuding filter figured I would ask since I have half the damn sled apart for the filter is there anything else to check while im in there? thanks as always in advance! jdp
Indy
check your tie rod back stop nuts. A good cleaning. check wires for potential rub through.
jdp1under
- Oct 19, 2009
- CT, NO SNOWVILLE
Check the wires and gave it a clean didnt look at the tire rods but will this week. thanks jdp
low slung
- Feb 16, 2005
Check underneath the plastic plate for the bottom of the motor(where you drain oil from the base)for hoses rubbing.
jdp1under
- Oct 19, 2009
- CT, NO SNOWVILLE
Thanks will do!
Theblackbullet
- Jan 12, 2010
- NW Ohio
- 2004 RX Warrior
Underneath your secondary, the drive shaft bearing and speedo pick up. If the bearing goes, your sensor is doomed haha. I know its not is the front by the filter but still important IMO..... It happened to me
Daranello
Suspended
Clean your metel oil screen on the bottom of the oil tank...my 2011 Apex was cruded up...
jdp1under
- Oct 19, 2009
- CT, NO SNOWVILLE
I will check it out! thanks
jdp1under
- Oct 19, 2009
- CT, NO SNOWVILLE
Dumb question but this is from the manual and its confusing the hell out of me.
Quantity
Total amount
3.8 L (3.3 Imp qt, 4.0 US qt)
Periodic oil change
2.8 L (2.5 Imp qt, 3.0 US qt)
With oil filter replacement
3.0 L (2.6 Imp qt, 3.2 US qt)
so how much oil am I putting back in the tank any in the motor direct? never did the full change before with hilter so i just want to make sure Im doing it right!
Quantity
Total amount
Periodic oil change
Indy
I put one down the top and 2 in the tank, start it up and get warm. Shut off and check the dip stick with the dip stick unscrewed and just resting on the top. It is a dry sump system, so a little over or under is fine, I usually go over.
Sasquatch
- Apr 17, 2004
- North Western Ontario
- www.dptc.com
- Yamaha's
I don't know why people think you need to add oil to the motor. That is only needed on a complete motor rebuild. I add oil 2 and a half to the tank. Then run it till operating temperature and top off.
Adding it to the motor will not hurt it I guess, the scavenger pump will just pump it to the tank so it can be sucked into the pressure pump and to the bearings. Seems pointless to do it.
As was said check with dipstick just resting in the hole not threaded in.
YammyRX1
- Jan 26, 2009
- Milton, on
- 2003 Yamaha RX-1
jdp1under said:Dumb question but this is from the manual and its confusing the hell out of me.
Quantity
Total amount
Periodic oil change
I believe it is 3.8 totally dry (like after rebuild), 2.8 if you just change the oil (not the filter), 3.0 if you change oil and filter.
Indy
Sasquatch said:I don't know why people think you need to add oil to the motor. That is only needed on a complete motor rebuild. I add oil 2 and a half to the tank. Then run it till operating temperature and top off.
I have a problem with cranking a dry motor. Thats why I drop a quart in the top.
YammyRX1
- Jan 26, 2009
- Milton, on
- 2003 Yamaha RX-1
I've been meaning to attach a rare earth magnet to the drain plug, now's a good time for you if you haven't finished and want to do it.
jdp1under
- Oct 19, 2009
- CT, NO SNOWVILLE
Thats a hell of an idea I assume your talking about right to the bottom of the drain bolt inside the tank? Where would you get one?
