A couple of bucks
- Jul 19, 2011
New guy here....over here from the smoking lounge. Looking to get an EPS sled because of physical issues. Need opinions on best EPS sled w/ ES,rev, a 136 or 144 and cushy ride. Speed/performance is no longer a issue w/ my condition. Just lookin to get back out on the trail. Oh yea....I'm 6'3", 295# w/o my gear.
yamaha1973
- Nov 27, 2011
- St. Peter Minnesota
- 2014 Viper XTX SE
TRUE BLUE SINCE 1980
What He Said!!!yamaha1973 said:
kinger
I would get a used apex XTX (still like speed) or do some homework on a Venture model they are nice and cushy.
A couple of bucks
- Jul 19, 2011
Burnoutink suggested an Apex XTX over on my post in the smokin side. I just do not want or need all that power/temptation.Although the Venture is the same displacement.....just w/ 3 holes instead of 4. Didn't know how the power distrubution differed between the two?kinger said:I would get a used apex XTX (still like speed) or do some homework on a Venture model they are nice and cushy.
Was looking at this
http://www.yamaha-motor.com/sport/produ ... specs.aspx
A couple of bucks
- Jul 19, 2011
On a toss up between the Vector LTX and the Venture TF.....whats the verdict? And likes/dislikes of either.
Ding
EPS does cut down on the arm and shoulder strain. I think this might be huge in your case. Venture is going to give a cushier ride even for a single rider of your physique. I would look for a Venture, but the Vector is nice too.
Honestly for myself, I preferred the Apex XTX the best for harder riding on bumpy trails. Even over the Nytros. But I am still able to ignore the pain of past sins for the most part. I love how the 144 bridges the smaller bumps.
IAVECTORGT
- Oct 19, 2011
- Iowa City, Iowa
- 2015 Arctic Cat ZR 8000 El Tigre
What he said also!!!TRUE BLUE SINCE 1980 said:What He Said!!!yamaha1973 said:
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
yamaha1973 said:
I seen this written about the Vector in the link above.
Is the Apex also now in a Deltabox 3 chasis?
Other than what is written below, are there other changes between the 2?
•Deltabox® III with comfortable rider-forward position
The primary design objective of the Deltabox III chassis was to create a comfortable rider-forward posture. The ergonomic treatment is achieved by locating the handlebars and seated position high and forward on the chassis. With this positioning, the rider can go from sitting to standing and back again easily and comfortably. It also centralizes the combined mass of sled and driver, for razor-sharp handling.
A couple of bucks
- Jul 19, 2011
It sounds like the Vector is a slightly better option? If I'm hearing correctly.
2013 Vector
Engine
Type / Displacement / cc Four-stroke, 1049cc
Cylinders Three
Horsepower Class 120 HP
Cooling Liquid
Bore & Stroke / mm 79.0 X 66.2
Intake Design 2 valves
Fuel Delivery 3 x 41mm fuel injection
Ignition Digital T.C.I. w/throttle position sensor
Exhaust Rear exhaust
Clutch / Transmission YVXC, variable ratio
Disc. Brake Type 4-piston hydraulic w/ lightweight ventilated disc
Chassis
Front Suspension Independent, double wishbone
Front Shocks 40mm aluminum HPG
Front Travel / in. 8.5 in
Ski Type Lightweight plastic, saddleless design
Carbide Ski Runners Standard
Stabilizer Bar Standard, linear ratio
Rear Suspension Mono Shock® II CK 136
Rear Shocks 46mm aluminum HPG w/ clicker
Rear Travel / in. 11.7 in
Track Type Camoplast® Rip Saw™
Dimensions
Overall Length / in. 118.1 in
Overall Width / in. 48.0 in
Overall Height / in. 45.7 in
Track/Width x Length x Height / in. 15 in x 136 in x 1.25 in
Ski Stance (ctr. to ctr.) in. 41.3 in
Fuel Capacity / Gal. 9.2 gal
Fuel Type Regular Unleaded
Oil Capacity / Qts. 3, dry sump
Engine Oil Type Yamalube 4, 0w-30, Cold Weather Formula
Features
Electric Start Standard
Reverse Standard
Hand & Thumb Warmers To-the-end, 9-position adjustable
Windshield Height Tall
Mirrors Optional
Seating Capacity One
Backrest N/A
Rear Carrier Rack N/A
Tow Hitch N/A
Tunnel Protectors Standard
Headlight Watts, Type 60/55W Halogen x 2
High Beam Indicator Standard
Oil & Temp Light Standard
Fuel Gauge Type Electric (LCD), low fuel warning light
Speedometer Standard (LCD digital)
Odometer Standard (large LCD display)
Tripmeter Standard, Dual (large LCD display)
Tachometer Standard (LCD)
DC Outlet Automotive & RCA
Warranty 1 Year (Limited Factory Warranty)
2013 RS Venture TF
Engine
Bore & Stroke / mm 79.0 X 66.2 82.0 X 66.2
Clutch / Transmission YVXC, variable ratio YVXC, variable ratio
Cooling Liquid Liquid
Cylinders Three Three
Disc. Brake Type 4-piston hydraulic w/ lightweight ventilated disc 2-piston hydraulic w/ lightweight ventilated disc
Exhaust Rear exhaust 2 valves, rear exhaust
Fuel Delivery 3 x 41mm fuel injection 3 x 41mm fuel injection
Horsepower Class 120 HP Spec Not Available
Ignition Digital T.C.I. w/throttle position sensor Digital T.C.I. w/throttle position sensor
Intake Design 2 valves 2 Valves
Type / Displacement / cc Four-stroke, 1049cc 4-Stroke / 1049cc
Chassis
Carbide Ski Runners Standard Standard
Front Shocks 40mm aluminum HPG 36mm aluminum HPG
Front Suspension Independent, double wishbone Independent, double wishbone
Front Travel / in. 8.5 in 8.6 in
Rear Shocks 46mm aluminum HPG w/ clicker 36mm aluminum HPG / 36mm aluminum HPG
Rear Suspension Mono Shock® II CK 136 ProComfort® w/ articulated rails
Rear Travel / in. 11.7 in 13.8 in
Ski Stance (CTR. TO CTR.) : mm (inch) Spec Not Available 42.8
Ski Type Lightweight plastic, saddleless design Lightweight plastic, saddleless design
Stabilizer Bar Standard, linear ratio Standard
Track Type Camoplast® Rip Saw™ Camoplast® Rip Saw™
Dimensions
Engine Oil Type Yamalube 4, 0w-30, Cold Weather Formula Yamalube 4, 0w-30, Cold Weather Formula
Fuel Capacity / Gal. 9.2 gal 9.2 gal
Fuel Type Regular Unleaded Regular unleaded
Oil Capacity / Qts. 3, dry sump 3, dry sump
Overall Height / in. 45.7 in 52.4 in
Overall Length / in. 118.1 in 123.4 in
Overall Width / in. 48.0 in Spec Not Available
Ski Stance (ctr. to ctr.) in. 41.3 in 42.8 in
Track/Width x Length x Height / in. 15 in x 136 in x 1.25 in 15 in x 151 in x 1.25 in
Features
Backrest N/A Standard, removable, adjustable tilt
DC Outlet Automotive & RCA Automotive & RCA
Electric Start Standard Standard
Fuel Gauge Type Electric (LCD), low fuel warning light Electric (LCD), low fuel warning light
Hand & Thumb Warmers To-the-end, 9-position adjustable Standard
Headlight Watts, Type 60/55W Halogen x 2 60/55W Halogen x 2
High Beam Indicator Standard Standard
Mirrors Optional Standard
Odometer Standard (large LCD display) Standard (LCD display)
Oil & Temp Light Standard Standard
Rear Carrier Rack N/A Standard
Reverse Standard Standard
Seating Capacity One Two
Speedometer Standard (LCD digital) Standard (LCD, digital)
Tachometer Standard (LCD) Standard (LCD)
Tow Hitch N/A Optional
Tripmeter Standard, Dual (large LCD display) Standard (tripmeter, LCD, digital)
Tunnel Protectors Standard Optional
Warranty 1 Year (Limited Factory Warranty) 1 Year (Limited Factory Warranty)
Windshield Height Tall Extra tall
2013 Vector
Engine
Cylinders Three
Cooling Liquid
Chassis
Dimensions
Features
Reverse Standard
Mirrors Optional
Backrest N/A
Tow Hitch N/A
2013 RS Venture TF
Engine
Chassis
Dimensions
Features
- 13K
