coolant 07 apex rtx
apexrtx10
Tribes Hill NY
I'm going to be replacing coolant in sled. It still has the 100% glycol in it and temp light will come on in low snow conditions. I would like to know what type of coolant and how much should go back in. Also whats easiest way to drain old coolant out? :rocks:
universal coolant from your local parts store is fine...add a little watter wetter..will help keep it cool...i also add BG stop leak...its a root that swells with contact to oxygen...will save an engine if you throw a stud!
50/50 mixture, 1/2 bottle of water wetter, get all the air out, you'll be good to go, after i did that, sled has never over heated again
