Found a coolant leak on the chain case side heat exchanger in the tunnel. It is located right by the bracket that
the rear axle and skid frame mount into the tunnel. my question is what is the easiest way to fix this? remove the exchanger from the tunnel or try doing it right in place. Next question is what is the easiest way to drain coolant? All
help would be greatly appreciated.
