Dakb
- Apr 28, 2023
- Nord
- Norway
- SW BTX Le 2017
Hi,
I have a SW BTX LE 2017, and I noticed by coincidence that the coolant level was half full.
I havent gotten any warnings or errors, but is this normal and OK to ride with?
DTJ
- Mar 31, 2016
- Brainerd, MN
- 2023 Yamaha Sidewinder XTX
2017 Yamaha Sidewinder BTX
Half full shouldn't cause any problems. You may want to check and tighten all your coolant fittings. My 2017 slowly lost coolant until I discovered about 6 hose clamps that needed tightening. Your coolant level shouldn't move once the system is completely sealed up.
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
Half full?
the Fill Cold line on your reservoir is where it should be which is below half full for that reservoir!
Otherwise, Half Full where? how would you know?
But yes it should stay on the cold fill mark unless warm, then the coolant does expand when it gets warmer, so it will go over the line, and will overflow if overheating!
kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
Check your oil level to make sure its not increasing. Fill to cold line and make sure to bleed it following this guy:
GR8BBQ
- Mar 23, 2018
- Hamlin, NY
- 2017 Yamaha SRViper X-TX SE
2017 Ski-Doo Blizzard 900 ACE
2001 Yamaha SXR 700 Triple
1995 Polaris Indy Lite
Are you sure it wasn't half empty?
