coolant loss
TBay Sledhead
Thunder Bay, Ontario.Ca
Canada
06 Attak
01 SXR Long Track
I wondering if anyone can help me out with a coolant loss problem. I loose approx 1/2 liter every 200 mi. When the sled is running there is a steady stream of coolant coming out of the rad cap into the overflow bottle and there seems to be a slight oil film on top of the coolant. I have pressurized the cooling system to try and find a leak but can't find one. I have pressurized each cylinder with 100 psi air pressure to see if there is a leak from the combustion chamber to the cooling system, but none. Any ideas.
