greenmntpass
- Jan 7, 2005
- Middlebury, Vermont
- 2000 SRX
Sparky your the man, I thought I was the one that would have used a turkey baster. Just drained the reservoir with it and replaced with distilled water, no problems since.
gamer1
- Mar 14, 2005
for draing oil and anti freeze I use a turkey baster with about 3 feet of clear fuel line to get down into the tanks, I remove the rubber end piece you pump then I can suck up the liquid and because the fuel line is clear I know when to stop. works well and is alot faster.
All those methods are fine and all will work. But here is myy point you have the tester in your hand with the rad cap off and fluid in the tester already. Instead of squeezing it back to the resevoir put it in a container for future use. Fill up your tester 3 more times to empty the resevoir and fill with distilled water. Done in five minutes start to finish.
Quad Power
- Dec 2, 2005
- Northeast Michigan
- www.mylesinsurance.com
Shaf said:Whats the cost of the rear heat exchanger installed otd.
My Attak's rear heat exchanger cost about $78.00 and took 1 1/2 hours to put it in with 2 people..........so I'm not sure how much a dealer would charge to install it. I guess whatever he charges per hour......and then he should have no more than 1 1/2 hours time.
