RX1T Veteran Joined Feb 14, 2008 Messages 28 Reaction score 0 Points 831 Location Sweden Jan 2, 2010 #1 Does anyone have some pics of where to hookup the cooling lines from the turbo? Turbo is frontmount Garrett... Should put a T in the line from the oilcooler and one to the thermostate? Is this right? R RED Lifetime Member Joined Apr 20, 2004 Messages 1,058 Reaction score 23 Points 923 Location alberta Jan 2, 2010 #2 The line that goes from the t-stat to the oil cooler is the right line. T-stat to turbo with stock line. Then new line from turbo to oil cooler. RX1T Veteran Joined Feb 14, 2008 Messages 28 Reaction score 0 Points 831 Location Sweden Jan 3, 2010 #3 Thanks ! You must log in or register to reply here. Similar threads G turbo install GOVENOR Dec 2, 2009 4 Stroke Turbos/Supercharger Replies 1 Views 1K Dec 3, 2009 FLYBYU Turbo Question ? givemeaboost Mar 25, 2007 4 Stroke Turbos/Supercharger Replies 6 Views 1K Mar 28, 2007 Travis Moore T D T vec cooling lines and oil valve dirk_03 Dec 6, 2009 4 Stroke Turbos/Supercharger Replies 2 Views 696 Dec 6, 2009 RED R MCX oil return pump jhlarsen Dec 10, 2017 4 Stroke Turbos/Supercharger Replies 0 Views 770 Dec 10, 2017 jhlarsen Brittle Coolant lines to turbo. What should I replace with? tonykof Jan 19, 2009 4 Stroke Turbos/Supercharger Replies 6 Views 884 Jan 20, 2009 mbarryracing Share: Facebook Bluesky LinkedIn Reddit Pinterest Tumblr WhatsApp Email Share Link
