cost of Fox Float rebuild
Mercer5
Wales WI
2014 Viper, 2001 SRX, 1990 Sno Scoot, Kitty Cat
Both my shock leak oil, anyone had them rebuilt yet and what was cost?
What model of sled and year is it..."FOX" on APEX RTX are AIR, no oil in them? if you have OIL their OHLINS or KYB on other models...
Sorry that's just not true. They run valve stacks like any other shock.
The air is in place of the spring, they still use oil or the dampining. Any shock place that does Fox should be able to rebuild them, No real valve changes needed unless you are unhappy with the ride. Should be around $60-$100.
there should be a little lube on the outside of the shock as well according to the book as a antfriction lube for when it sledes up and down. thats not the oil you see is it as i thought mine was leaking as well until i read the book lol.
I have 2800 miles on them so I don't think its break in oil anymore or lube of any type. Its dark so I assume I have a seal out. I will have rebuilt.
thanks
thanks
its not break in oil we are refering to as like he said its ant-fritcion lube which more of a film of oil. if it was leaking im guessing it would be all oily more them a film.
cire said:
Try Goodwin Performance but I don't know any prices.
I agree! Their prices are on the website. Kurt is real helpfull. They had good prices compared to Hygear, and There turnaround time is only 2-3 day right now. They are both good from what I hear. Just had good personal luck with Goodwin. They are in Zion IL.
