thunderbolt
I have a LTX SE with the white side plastic and would like to change it to the blue like the LE , can these panals be bought complete with the decals ? If so does anyone know the part numbers
Chris Rose
- Jul 29, 2016
- Powassan ONT
- 2017 sidewinder stx-DX with TD/Max 16 stock muffler
- chrisjrose2018@@gmail.com
Don't have the part number, but you can get complete panels just order for the ltx-le model. Yamaha calls them purple /deep blue. Complete gives you the decals and insulation.I have a LTX SE with the white side plastic and would like to change it to the blue like the LE , can these panals be bought complete with the decals ? If so does anyone know the part numbers
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
You can click around the online micro-fiche to check prices ....you want DPBSE(blue)
https://www.ronniesmailorder.com/oemparts/a/yam/59b6c5ba87a8661154941462/shroud
Example below
Example below
thunderbolt
Thanks Dan , by the way hows the snow where you are , we lost all ours !!!!!
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Muskoka lost a ton too...all from only one MILD day. Grrr
Saving grace is, we did not lose our base entirely....so the base in bush is now solid rock hard. And lakes are now all gonna be much thicker as all the snow on top went to slush Thurs, then froze up Fri AM....and its been sitting at minus 20 for a high today. Tonight will be down to minus 27 here.
Too bad not much snow in forecast at all, and the bigger issue is Georgian bay got a ton of ice cover on it with the frigid early season temps...and so now the Lake Effect snow Muskoka typically gets being in snow belts, will be NON existent going forward this winter.
Dan
