Cpr and Excell pipe (jet?)
Point&shoot
Need Jet and needle suggestion. Cpr kit orig is 130's need to go up or down Problem is I need a direction, no snow to test here and will be headed up to ride-(test) with the guys :o| when they are trail riding, my not have any freinds after. Motor has low comp, pistons try 10-12lbs boost. I have every gauge needed to tune from your suggestions.
On my CPR I'm running 135's and dumping straight into the tunnel but my setup allows the intake to get a lot of air. Needles are in the center right now usually riding at 6-8k feet
