Skydog
Man that sucks man!
Chrisinparts,
Ok its time to break down and admit to defeat. Just load her up and make that 8hr trip to Jeff and i'll bet within an hour or two he'll have
you all fixed up. Other wise your going to crack up. :ORC
TB
TB
chris, your going to end up wrecking something if you keep running it like this, bring it to me, it will be worth the 8 hr drive, and won't cost you anything for me to find your problem. jeff
Thrusted Vector
Did you ever check the fuel pressure?
Was the problem ever fixed?
chrisinparts
- Feb 10, 2004
- dearborn mi
- 05 rx1, 10 nytro, 10 z1 turbo
jeff simon has sled and is fixing and tuning for me. will let know when i get it back. thanks
problem is fixed, the sled left my shop tuned for the stock exhaust can modified to my specs and a stock 05 rear suspension, chris put on a gp-1 exhaust and a wahl rear suspension, nice pieces, but the exhaust requires jetting changes, and who knows what the clutching will need for the susp change, one needle clip and two main jet sizes richer, and it is running like a champ, made 212 hp on 8 lbs low boost, and 250 hp on 12 pounds hi boost, installing some guages on it for chris now, and we will tune the clutching for his 136 long track. set-up is everything, if you change things, you can't expect things to work the same. its too bad my kits rep had to suffer. jeff
Turbo Tim
Jeff , anyone can have probs. tuning any of the Turbo kits out there......your kits rep didn't suffer .......It's working great for me on my warrior ........
Silverbullet
By you taking the time to tune and obviously dyno test his sled... I'd say your rep has improved
