canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
I got mine off Flea bay for about $5.00 ea. Just have a look around there, a couple of guys are solid plug merchants. Watch the shipping also!
Beenba
- Feb 16, 2011
- 2009 Nytro XTX
so a 10ek is colder than the 9 ek? weird, I thought putting in a hotter plug would make more power!
Bahr05
- Dec 18, 2010
- Medford, WI
- '09 Nytro XTX
After reading this post, i bought a set of 4 off fleabay for $28 and free shipping.
axapowell
Beenba said:so a 10ek is colder than the 9 ek? weird, I thought putting in a hotter plug would make more power!
Not really, go to NGK's website and read up on the theory!
Plus, I'll always believe Ulmer's results.
Dave
axapowell
From the NGK website:
FAQs - Spark Plugs
Q: Why are there different heat ranges?
A: It is a common misconception that spark plugs create heat. They don't. A heat range refers to how much heat a spark plug is capable of removing from the combustion chamber.
Selecting a spark plug with the proper heat range will insure that the tip will maintain a temperature high enough to prevent fouling yet be cool enough to prevent pre-ignition. While there are many things that can cause pre-ignition, selecting a spark plug in the proper heat range will ensure that the spark plug itself is not a hot spot source.
FAQs - Spark Plugs
