Cracked bulk-head repairable?
big_red1a
Moose Jaw, SK Canada
Found a small crack high in my bulkhead were the rivit holdes on the plastics. Can It be welded? What is it made of? Would I have to remove it from the sled or can i disconnect the battery and weld in place?
I have been using a product called HTS-2000 recently with real good results.
I researched it on line and then bought it off ebay for like 10-15 bucks for 5 rods. I did some weld tests with it first then tried it on my sled.
I have patched 3 different holes in heat exchangers but have not tried it on a bulkhead.
the stuff melts at 700 degrees. about 500 below the aluminum melt point. You heat the area with a torch and once it is hot enough apply the rod to it. the rod melts into the broken material simple as that.
I know it sounds too good to be true but trust me. if you follow the directions it works.
do a search on hts-2000. company claims you can weld just about anything with it. there are videos of how to do it on thier web site too.
Good luck
