DUTCH OVEN
I was checking out my rear skid today before ride, 08 LTX and noticed the support rail was cracked again. Between both sides I replaced these things 3 times each totall of 6 now. Anybody else have this problem.
Long Track
Yes.
Have 3 riding partners with Attaks and 2 of them have cracked the rails as well. Think it's more common than we think.
The cracked rails are due to the force or twisting of the rail applied by the independent rear idler wheel mounts. Eventually the rails crack at the rear pivot arm bolt hole.
To stop this from happening again, I got rid of the rear idler wheel mounts and installed a solid axle with the idlers attached. If you look at a 2010 skid Yamaha did something similar except with no idlers on the shaft.
I'll post some pics when I get a chance.
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
Were your rails all covered by warranty?
berge75
Yamaha dosen't warranty rails.
yamiboost
- Feb 17, 2008
- Labrador,
- 15 SR Viper MTX Hurricane 300hp kit
Fx Nytro Drag Sled 25psi + Boss Nos
I dont know if they do now but they use to i had mine replaced on warranty.berge75 said:Yamaha dosen't warranty rails.
big_red1a
I have cracked 2 rails as well on a 08 ltx. Interested in seeing the 2010 spacer long track is talking about. I bought the spacer and ready rod and forgot where I was going to put it over the summer lol!
woodysattak
- Apr 15, 2010
- Union Grove WI
- 2017 RTX LE
- Waterford WI
cracked rails
Mine cracked too right by the rear mounting bolts for the rear suspension. Took to a local shop and had it welded and a reinforcement plate put in for fifty dollars. Trust me it will never crack again. Very simple fix for a good machine shop.
Long Track
Pics as mentioned, first pic my sled with idler wheel axle (skid a little dirty from snirt) and SS backer plate, 2nd pic 2010 LTX.
hellflyer
- Dec 2, 2008
- Georgtown ONT. Canada
- 2020 sidewinder ltx se
I did the same thing on my 08 the first year I owned it.Used the one out of my 03 viper,as a trial,fits perfectly wheels and all.Got 10000k on mine now and no cracks.
