YammieMan
- Feb 26, 2019
- Winkler
- 2003 Yamaha RX1
So I rode 50 miles and the sled worked awesome. Wanted to ride the next day, no go! It cranks but doesn't run. I did so e research and charged the battery and also replaced all plugs. I borrowed a plug tester and no spark. I cam hear the fuel pump working but now I'm lost. Some of the reading I have been doing stated a stator or crank sensor. The engine light is blinking and code 12 appears on display. Any help would be awesome! As you are all professionals! Thanks
Stubbs
- Nov 7, 2006
- Uxbridge, On, Can.
+ other gooodies
- Uxbridge ON
It’s the crank position sensor, which is part of the stator assembly. Pretty common failure with Apex’s that have some miles on them, time to replace it.
RobX-1
- Coldwater, OH
I was just going to say the same thing as my 08 Apex had the same symptoms; the code 12 was the tell-tale sign. It's not a bad job to do as you just need to remove the oil tank to access the crank case cover. However, the bolts for the cover vary in length so you have to keep track of which one goes where. I just used a marker and labeled the one bolt hole that was at the 1'oclock position #1 and then labeled a small dixie cup with the same number and put the bolt in it. Then going clockwise, repeated process until all 11 bolts were accounted for. When it comes to repairing, you have two options; 1) just replace/splice in new aftermarket sensor as OEM does not offer one or 2) replace with OEM stator assembly which comes with the crank sensor. Obviously, option #2 is more expensive but some have had issues with just doing option #1. I opted to do option #2 as I was planning on keeping this Apex and wanted the piece of mind if was fixed properly. If you do opt to replace yourself, be sure to order the crank cover gasket as it is not listed with the stator assembly. Also, when removing the cover, realize there is a strong magnetic pull that will make it seem to not want to come off. This also means upon re-assembly, the cover will want to snap together very quickly so be sure to have a good grip and watch those indexes.
YammieMan
- Feb 26, 2019
- Winkler
- 2003 Yamaha RX1
Ok .. it has 11,400 miles.It’s the crank position sensor, which is part of the stator assembly. Pretty common failure with Apex’s that have some miles on them, time to replace it.
x3 on crank position sensor. been there.
YammieMan
- Feb 26, 2019
- Winkler
- 2003 Yamaha RX1
Thanks for information! So would you go with a aftermarket stator? As I priced out a oem And it's like 500.00 . Or aftermarket. ? And if so which brand.? You have part numbers? Thanks again!I was just going to say the same thing as my 08 Apex had the same symptoms; the code 12 was the tell-tale sign. It's not a bad job to do as you just need to remove the oil tank to access the crank case cover. However, the bolts for the cover vary in length so you have to keep track of which one goes where. I just used a marker and labeled the one bolt hole that was at the 1'oclock position #1 and then labeled a small dixie cup with the same number and put the bolt in it. Then going clockwise, repeated process until all 11 bolts were accounted for. When it comes to repairing, you have two options; 1) just replace/splice in new aftermarket sensor as OEM does not offer one or 2) replace with OEM stator assembly which comes with the crank sensor. Obviously, option #2 is more expensive but some have had issues with just doing option #1. I opted to do option #2 as I was planning on keeping this Apex and wanted the piece of mind if was fixed properly. If you do opt to replace yourself, be sure to order the crank cover gasket as it is not listed with the stator assembly. Also, when removing the cover, realize there is a strong magnetic pull that will make it seem to not want to come off. This also means upon re-assembly, the cover will want to snap together very quickly so be sure to have a good grip and watch those indexes.
YammieMan
- Feb 26, 2019
- Winkler
- 2003 Yamaha RX1
Also do I drain the oil? Or can I move it far enough out of the way? ThanksI was just going to say the same thing as my 08 Apex had the same symptoms; the code 12 was the tell-tale sign. It's not a bad job to do as you just need to remove the oil tank to access the crank case cover. However, the bolts for the cover vary in length so you have to keep track of which one goes where. I just used a marker and labeled the one bolt hole that was at the 1'oclock position #1 and then labeled a small dixie cup with the same number and put the bolt in it. Then going clockwise, repeated process until all 11 bolts were accounted for. When it comes to repairing, you have two options; 1) just replace/splice in new aftermarket sensor as OEM does not offer one or 2) replace with OEM stator assembly which comes with the crank sensor. Obviously, option #2 is more expensive but some have had issues with just doing option #1. I opted to do option #2 as I was planning on keeping this Apex and wanted the piece of mind if was fixed properly. If you do opt to replace yourself, be sure to order the crank cover gasket as it is not listed with the stator assembly. Also, when removing the cover, realize there is a strong magnetic pull that will make it seem to not want to come off. This also means upon re-assembly, the cover will want to snap together very quickly so be sure to have a good grip and watch those indexes.
RobX-1
- Coldwater, OH
Unfortunately, I went OEM on the stator assembly so that's the only part numbers I would have. I do know that Travis (@hibshman25) of Barn of Parts (TY Vendor) offers either an aftermarket stator assembly or sensor.
https://barnofparts.com/apps/webstore/products/category/1489074?page=1&siteId=134334799&locale=en-US
RobX-1
- Coldwater, OH
As for the oil in the tank, I removed it as I did the oil change at the same time. It's also nice having that extra room with it being out of the way because again, of the magnetic pull of the crankcase cover.
Stubbs
- Nov 7, 2006
+ other gooodies
- Uxbridge ON
No need to drain the oil. I’d give Travis a shout like mentioned above if I was you and take it from there.
YammieMan
- Feb 26, 2019
- Winkler
- 2003 Yamaha RX1
Ok.. sounds awesome! Travis is a great guy. Have bought stuff of of him beforeAs for the oil in the tank, I removed it as I did the oil change at the same time. It's also nice having that extra room with it being out of the way because again, of the magnetic pull of the crankcase cover.
YukonMP
- Dec 25, 2014
- Yukon Territory
From hanging around here for a while I can tell you that aftermarket electrical parts do not hve a good reputation. This is not personal experience, just what I see reported.
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
2016 Apex XTX
Buy the OEM replacement.
I've done this repair on 3 or 4 06-07 Apex's. Normally I would agree that OEM is better, however, I just replaced the pickup coil only on all the ones I did and they have worked fine. I get mine from a place in Stratford called MC distributing. Only about $70
Of note, you should do a visual inspection of the stator, as dark discolouring is an indicator that it may be on its way out. In that case, you'd want to buy a complete stator assembly.
YammieMan
- Feb 26, 2019
- Winkler
- 2003 Yamaha RX1
Emailed Travis. Getting it figured out. Sounds like maybe just a pick up coil.No need to drain the oil. I’d give Travis a shout like mentioned above if I was you and take it from there.
