RobX-1
- Coldwater, OH
More than likely, that's probably the case as my stator appeared to be fine but the the pickup coil was bad. I was going to just replace the pickup coil but with an aftermarket pickup coil, you have to ensure the stator/sensor (pickup coil) gap is correct which some had to oblong the bolt holes on the RM Stator sensor to get correct gap. I'm not sure what brand Travis offers or if this would need to be done with his pickup coil but may be something you will have to account for. Although I did opt to replace the stator/sensor with OEM parts and have not had a problem with it, I did the opposite when replacing the starter and went with the aftermarket one Travis offers and have not had a problem with it either.
Good point. Before unbolting the parts from the cover, I measure the distance between the stator and the magnetic tab of the pickup coil. That way I can verify the gap after installing the new pickup coil. Also of note is that sometimes these are polarity sensitive. You will know if its wrong as the machine may not start normal, or else idle strange. If its wrong, I just switch the wires at the plug.More than likely, that's probably the case as my stator appeared to be fine but the the pickup coil was bad. I was going to just replace the pickup coil but with an aftermarket pickup coil, you have to ensure the stator/sensor (pickup coil) gap is correct which some had to oblong the bolt holes on the RM Stator sensor to get correct gap. I'm not sure what brand Travis offers or if this would need to be done with his pickup coil but may be something you will have to account for. Although I did opt to replace the stator/sensor with OEM parts and have not had a problem with it, I did the opposite when replacing the starter and went with the aftermarket one Travis offers and have not had a problem with it either.
idontknowjack
- Mar 22, 2020
- SW Ontario
- '20 SRX
Check the resistance. Should be around 0.5 ohms.Emailed Travis. Getting it figured out. Sounds like maybe just a pick up coil.
Pickup coil is 500ishCheck the resistance. Should be around 0.5 ohms.
YammieMan
- Feb 26, 2019
- Winkler
- 2003 Yamaha RX1
I tested mine it is 500ish kilo ohmsPickup coil is 500ish
So that would be 500,000 ohms???
If you don't just replace the trigger then go with the OEM replacement stator...if you look at the current Yamaha replacement stator it has a -02 included in the part number which means its been updated twice. Stick with the OEM part it will pay off in the long run.
JM.02c
JM.02c
Maybe it just depends on here your multimeter is set? Spec is 500 ohmsI tested mine it is 500ish kilo ohms
Especially if the OEM isn't much more money.If you don't just replace the trigger then go with the OEM replacement stator...if you look at the current Yamaha replacement stator it has a -02 included in the part number which means its been updated twice. Stick with the OEM part it will pay off in the long run.
JM.02c
Don't forget however that some of the Yamaha stators were of poor quality right from the get-go. Tons of 00-02 SRX and 02 Viper stator failures with low miles. Those early Apex had plenty of pickup coil failures. I f Yamaha cared about the consumer more, they would make the pickup coil available separately, instead of having to toss the rest of the charge stator in the scrap metal bin.
YammieMan
- Feb 26, 2019
- Winkler
- 2003 Yamaha RX1
I set it to ohms. But it automatically jumped to kilo ohmsMaybe it just depends on here your multimeter is set? Spec is 500 ohms
YammieMan
- Feb 26, 2019
- Winkler
- 2003 Yamaha RX1
A new oem is 500.00 . Seems like a waste of money as the stator is fine. Unbelievable that you can't get that sensor separately.Especially if the OEM isn't much more money.
beanie
- Jun 11, 2005
I have 2 07 attaks, both failed around 10k miles . I used RM pickup coils and both worked fine with no adjustments . 30.00 Ebay at the time .A new oem is 500.00 . Seems like a waste of money as the stator is fine. Unbelievable that you can't get that sensor separately.
