Cranksensor?
Directions, shmirections lol! Who uses those? Ha ha.
No issues once the rm pickup was replaced with OEM so proper gap could be set.
My sled had issues starting. Thought I was gas or plugs. I got it started. Rough start. Backfiring etc.
Went for a test run tonight. Ran amzing . Then the speedo stopped. Lights flickered. Sled died. It started drove then stalled.
Idled okay but dies when throttle was pushed.
Error 12.
18000kmnon my apex gt.
Crank sensor?? Stator should I do both or just the sensor.
Sound familiar.
Any advice much appreciated.
i would do both if you plan on keeping the sled and only use oe. see quite a few issues crop up from people using aftermarket stators. make sure you order the gasket for the crankcase cover as they can tear on disassembly.
also clean all the grounds while it is apart. might save some future issues.
