blevis213
- Apr 13, 2013
- hadley, new york
- 2014 apex se
2001 srx 700
2000 srx 700
2021 sidewinder srx
Was told to use a crush washer for the oil drain plug. Anyone else doing this and what you torquing it to thanks
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
I just use the stock oil drain plug gasket for a Toyota. Fits perfect, way better than the o-ring that rips out.
Turboflash
- Mar 18, 2019
- Southern MN
P/N or what year/make/model Toyota, or are they all same?I just use the stock oil drain plug gasket for a Toyota. Fits perfect, way better than the o-ring that rips out.
I have friends that need these. They struggle with factory orings.
Tks!
STAIN
- Feb 29, 2004
- Vermont
- Vermont
GR8BBQ
- Mar 23, 2018
- Hamlin, NY
- 2017 Yamaha SRViper X-TX SE
2017 Ski-Doo Blizzard 900 ACE
2001 Yamaha SXR 700 Triple
1995 Polaris Indy Lite
Is this for the drain bolt in the footwell, or the drain bolt under the access panel near the oil filter?
blevis213
- Apr 13, 2013
- hadley, new york
- 2014 apex se
2001 srx 700
2000 srx 700
2021 sidewinder srx
drain bolt under oil tank in the footwell area
Turboflash
- Mar 18, 2019
- Southern MN
Tks!
Upstater57
- Apr 25, 2021
- New York
- 2022 Tcat EPS,
2014 ZR9000 (sold)
1978,1979,1980 SRX (sold)
There is a new rubber ring in the oil drain kit. The rubber ring on the plug should be changed out at every oil change.
