Cubby
- Dec 14, 2009
- South of Winnipeg, Manitoba CANADA
- 2015 Ski Doo 900 ACE Renegade Adrenaline
2007 Yamaha Phazer GT
I was at my local dealer to pick up oil for my oil change. When I asked for Yamalube chaincase oil he told me that don't use it because it causes leaks. They only use Torco synthetic chaincase oil. I told him I have never heard of any issues using Yamalube chaincase oil. I went to a different dealer and bought the Yamalube. Anyone have leaks with Yamalube? I did buy a new crush washer.
- Nov 1, 2009
- Winnipeg, Manitoba
- 2009 Phazer RTX
Never had an issuse with any brand of oil causing a leak in the chaincase.
Gone Blue
- Oct 11, 2006
- Howell, Michigan
I usually run Amsoil in my chain cases but had some Yamalube that I won at the TY Give Away ride last year that I put in with my track swap. I used the original crush washer and has been off twice and have over 700 miles on the Yamalube. No leaks. I can't believe that there is an issue running Yamalube. I think that is crazy dealer talk. G.B.
Cubby
- Dec 14, 2009
Now you know why I'm doing all my own work! What a joke.
Heck I even ran the Spectro tranny oil for dirtbikes in there one season since I didnt have chaincase oil handy.That dealer must have a bunch of Torco laying around.
20/80
- Mar 25, 2010
- Nova Scotia
- 2016 APEX LE XTX
Lol, Torco makes and is Yamalube.Cubby said:I was at my local dealer to pick up oil for my oil change. When I asked for Yamalube chaincase oil he told me that don't use it because it causes leaks. They only use Torco synthetic chaincase oil. I told him I have never heard of any issues using Yamalube chaincase oil. I went to a different dealer and bought the Yamalube. Anyone have leaks with Yamalube? I did buy a new crush washer.
Jeffz
- Feb 3, 2010
- Cresco, Iowa
- 2008 Yamaha Nytro RTX 40th
2007 Phazer "RTX"
Yamalube here with no leaks. As long as you get the cover on correctly, there shouldn't be any problems.
3wheelerdude
- Jan 6, 2010
- Ottawa Ontario
- 2019 Voyageur 600
2019 ZR200
1991 Ovation 340
1986 XLV 540
Previous sleds: 1996 Vmax600, 2007 Phazer, 2016 Bearcat 3000
How the heck would oil cause a leak?.....
Bad gasket, washer, drain plug or vent maybe, but the oil itself.....really.
If everything is sealed up good, you could put water in there and it shouldnt leak.
Cubby
- Dec 14, 2009
I think their problem is they're overfilling it! That will cause a leak!
YAMALUB CHAINCASE OIL IS NOT SYNTEC AND i DON'T KNOW IS FOR THIS REASON SO i SEE SOME HIGH HP SLED LIKE APEX THAT TOAST THE OIL VERY FAST AND BURN CHAIN CASE.... MAXIMA CHAINCASE OIL FULLSYNTEC AND NOW ZERO TROUBLE WITH APEX....
YAMALUB CHAIN CASE OIL IS PERFECT FOR BRAVO....LOL
NEVER HAVER LEAK EXPERIENCE
Weapon X
WHY ALL THE SHOUTING HA HA HA
BombaPolaYama
But why would only the Yamalube cause them to overfill itCubby said:I think their problem is they're overfilling it! That will cause a leak!
Cubby
- Dec 14, 2009
I did change the chaincase oil this weekend. Took forever for it to drain even with the sled tipped on its side. It was pretty murky from condensation. Filled it up with Yamalube chaincase oil. Ran the sled - no leaks.
