yamaha06
Hey guys was doing an oil change on the viper and when I pulled out the drain plug there is no washer or o-ring, do these sleds not have anything? The nytro had a washer but the viper just has the bolt, didn't see anything stuck to the bottom of the drain hole either. Wasn't sure if there sleds don't have a washer or did the dealer just forget to put it back on when they changed the oil last.
SnoNinja
aka "Plan B"
- Feb 18, 2015
- Gaylord, Michigan
- 2015 Viper LTX-LE
2016 Vector LE For my Bride
2007 Phazer GT, 136" Stretch.
2002 SXR600 (still own)
1997 SX600 (sold)
1997 XT500 (sold)
2013 Can-Am Maverick 1000XRS
Supposed to be rubber o-ring on the bolt. Maybe it's stuck up inside the hole. I'd check there.
yamaha06
Oh really, ya I will have to check in the hole. If it's not there can I just use a rubber o ring that fits the bolt? Or will I have to order one from the dealer.
SnoNinja
aka "Plan B"
- Feb 18, 2015
- Gaylord, Michigan
- 2015 Viper LTX-LE
1997 SX600 (sold)
1997 XT500 (sold)
Dealer might stock them as they tell you to use a new one every time. Might be worth a phone call if you can't find yours. It's part three in the Yamaha oil tank parts diagram.Oh really, ya I will have to check in the hole. If it's not there can I just use a rubber o ring that fits the bolt? Or will I have to order one from the dealer.
I wish they had a copper washer. Can get better torque on it
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
if you bought the Yamaha oil change kit(box with oil and filter from dealer) there is one that comes with the kit inside the paper funnel supplied in the kit.
