SISCAKIDD
For you guys running the curves skis,did you reuse the stock rubber blocks or did the curves come with specific hardware .want to put the curves that I was running on my XR1200 on and they went on with factor blocks.... Anyone know? Thanks
putz21
- Apr 15, 2013
- Tomahawk, WI
- '25 Sidewinder XTX LE w/EPS
'23 Sidewinder LTX LE w/EPS
The Curves came with the Rubber Blocks and hardware.
larrypolaris
Same here.
Nytro40th
- Sep 19, 2007
- Amherstview Ontario
- 2014 SR Viper RTX SE
same here.
csederlund
- Oct 7, 2012
- Frederic, WI
- 2014 LTX SE
I'm not sure if Curve Ind. only sells the rubber damper. I didn't see any on the website. I know C&A sells the damper for $10 and looks like the same.
superb
- Apr 10, 2004
- Ottawa, Ontario
- 2015 Viper turbo, 2013 Apex, 2012 Vector LTX, 2010 Vector LTX
I ordered the installation kit from Curve industries for my Viper, skis work great.I'm not sure if Curve Ind. only sells the rubber damper. I didn't see any on the website. I know C&A sells the damper for $10 and looks like the same.
SISCAKIDD
Thanks guys.... I have a call in to Curves ind,but they were all at a snow show ,prob the shoot out ,they will call on Monday and I see what I need.was not really thrilled with the tuners that came on my 15 LTX DX ,could have been the condition though .
Curve Industries
TY Advertiser
- Jan 20, 2008
- Waterville, NY
- www.curveindustries.com
Are you all set?
- Sean
- Sean
SISCAKIDD
Are you all set?
- Sean
Yes ,I ordered them correct mount kit from the website and the skis are installed,they were not easy to get on but I figured it out,thanks for checking
