I recently cut a 15" x 151" x 2" Skidoo track down to 14.25" for my Phazer. Thought I'd put this out there just to save someone there fingers after using a table saw. (Had it running then chickened out, I like my fingers). Also I was able to do the whole track myself, no help required.
All I used was a carpet style OLFA knife (the one with the hooked blades), a OLFA knife straight blade, a 18 TPI hack saw style blade for my Saws-all, and a 4" Grinder.
I considered using my table saw but when I realized how easy and accurate it is to cut the rubber with a blade I was hooked. The steps I followed were simple, just lots of repetition. Still, the whole thing took about four to five hours and the quality is excellent. (Looks factory other than the bars).
1. Place 3/8" (whatever thickness you want to take off each side)thick plywood jig on track edge and mark with a pen up the lug and along the track. I used 3/8 cause 15"-3/8"-3/8"= 14 1/4".
2. Cut the track with hooked knife up to the next lug.
3. Cut the lug with the straight blade using long sweeping cuts, like cutting a turkey!
4. Cut as close to the reinforcement bars as possible without touching the blade to the fiberglass, it dulls them real quick.
5. Use Saws-all to cut bar.
6. Repeat.
7. Every so often the Saws-all doesn't cut perfect so I would grind the excess with my grinder. I made a point of leaving excess after a while cause it looked so nice ground down. Makes for a nice seal to the edge because it melts it just slightly.
I used less than 2 hooked blades (four fresh edges per blade), about 8 straight blades, 2 Saws-all blades and my grinder wheel just looks a little blacker. Other than my time I think it probably cost $25.00 for tools. A lot cheaper than my table saw was!! In my opinion it was way safer just took a little longer.
Good luck!
Em
