Dalton Clutching
Yamaharida14
Saint John, N.B, Canada
I do mostly trail riding but I like to open it up on the strait aways. I have an RX1 with K&N's and Exell Pipe with DYP 57.5 weights with a black blue Dalton primary spring and running a 52R46 Helix with a red Dalton secondary spring set at 70deg with 24-40 gearing. My engagement is 4000 rpm but my shift point is falling a little flat at 10,000 rpm. I am thinking of dropping my weight to DYP 53 But I am also eyeing the DYPR weights but I no idea were to start for weight or spring for these weights. Anyone have any suggestions for me or opinion on these weights. Thanks
get a set of 58 gram dpyr and you can load weight if you need to. ive run the 62 g mt but the 58s are more tuneable. these weights are not as aggressive as the dpy and are similar to yamahas 8dn series.
