Carpet Guy
Whats a good Hurricane tune set up I have a 35/39 helix with dalton springs
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
PM hammer 70 if he is willing to share he has his clutches dialled in on his winderWhats a good Hurricane tune set up I have a 35/39 helix with dalton springs
race24x
Are you sure you dont mean 39/35? From what I have seen that is the correct number for a tuned sled. I am stock so I have a 35.
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
19s and 20s came with a 35/39 reverse helix.Are you sure you dont mean 39/35? From what I have seen that is the correct number for a tuned sled. I am stock so I have a 35.
Carpet Guy
Mine is a 18 and I just put a 35/39 on it19s and 20s came with a 35/39 reverse helix.
race24x
That may be, but I thought Hurricane and TD usually use a 39/35 instead, but ask around I may be reading that wrong
Attack gt
- Dec 28, 2010
- Damariscotta, Me.
- 2017 Sidewinder LTX
I also have a 35/39 reverse helix. I am running the Hurricane stock modified exhaust 270 tune. I just received the Turbo Dynamics clutch kit with both springs, HD rollers, and Dalton QAY 70 weights and after talking with them on the phone, they are suggesting I start off loading the weights to 74 grams. I am currently running the 8jp belt but may switch to the stock straight 35 degree helix and a xs825 belt. There certainly seems to be a lot of different combinations that are working for different people. I guess Its all just personal preference but no matter the setup, from what I understand, you want to be as close to the 8800 - 9100 rpms as possible as I believe that is were both TD and Hurricane build there power from what I understand.
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
I have never ran a reverse angle helix,so I don't know about them,but if you run your 35 stocker and the xs825 belt w/that tune you may want 73 plus grams of weight,to start and I bet your rpms will be close to 9000.I also have a 35/39 reverse helix. I am running the Hurricane stock modified exhaust 270 tune. I just received the Turbo Dynamics clutch kit with both springs, HD rollers, and Dalton QAY 70 weights and after talking with them on the phone, they are suggesting I start off loading the weights to 74 grams. I am currently running the 8jp belt but may switch to the stock straight 35 degree helix and a xs825 belt. There certainly seems to be a lot of different combinations that are working for different people. I guess Its all just personal preference but no matter the setup, from what I understand, you want to be as close to the 8800 - 9100 rpms as possible as I believe that is were both TD and Hurricane build there power from what I understand.
justinator
just my .05cents but I think you'll have a much easier time dialing in your clutching if you go back to a straight 35 helix. The reverse angle pulls rpms down as you get up to speed and this is amplified using dalton weights vs stock weights. I find the reverse angle to be more sensitive to changes in snow conditions, weather etc and proper weight location in the daltons becomes critical to not cause too low of a peak rpm. It can be done for sure but if you want to spend minimal time tuning and more time riding and likely have a more consistant setup the 35 will get you there
Carpet Guy
Thanks I was thinking of going back with stock helix and any idea where I should set the spring tojust my .05cents but I think you'll have a much easier time dialing in your clutching if you go back to a straight 35 helix. The reverse angle pulls rpms down as you get up to speed and this is amplified using dalton weights vs stock weights. I find the reverse angle to be more sensitive to changes in snow conditions, weather etc and proper weight location in the daltons becomes critical to not cause too low of a peak rpm. It can be done for sure but if you want to spend minimal time tuning and more time riding and likely have a more consistant setup the 35 will get you there
Carpet Guy
Mines a 1819s and 20s came with a 35/39 reverse helix.
justinator
l am currently working on that right now with my sled so I dont have any solid advise to give you. Are you running 8jp belt or ultimax? I know with the ultimax I'm gonna start at 3-3 with yamaha yellow spring but you mentioned you had dalton springs.....is it the black/orange? I believe guys are running that at 6-1 or 6-2. If your using the 8jp and a big tune Ive read guys are going with pretty stout springs to reduce the slipping. If you dont have an infared temp gun Id recommend picking one up, they can be had for cheap and better than sticking your hands on clutches to gauge temp. It'll take a little testing to find the the sweet spot where your happy with backshift and upshift characteristics and good clutch temps. Everyone has their own preference.Thanks I was thinking of going back with stock helix and any idea where I should set the spring to
Fast
- Sep 25, 2018
Dumb question but does the 35/39 reverse helix start at 39 degrees and finish at 35?just my .05cents but I think you'll have a much easier time dialing in your clutching if you go back to a straight 35 helix. The reverse angle pulls rpms down as you get up to speed and this is amplified using dalton weights vs stock weights. I find the reverse angle to be more sensitive to changes in snow conditions, weather etc and proper weight location in the daltons becomes critical to not cause too low of a peak rpm. It can be done for sure but if you want to spend minimal time tuning and more time riding and likely have a more consistant setup the 35 will get you there
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
Nope, it starts at 35 and goes to 39.
Reverse helix is just that, backwards from normal.
