Dalton primary spring B/BZ - length?
Janne339
Sweden
Sweden
2021 Sidewinder LTX GT
Anyone know the lenght of the Dalton black/bronze primary spring? Shorter than the 110 mm stock spring?
I believe its shorter but dont quote me. I have been using this spring for a while now and even switched over to Apex clutch and still using it. But now with Apex clutch and TD glide washers, engagement at 3500 and a little abrupt. Going to try without washers and see how that works.
Did you notice much difference with the Apex clutch performance wise?
The dalton black/bronze definitely engages higher mine is about 3500-3600. Stock spring was about 2900-3000. Lengths are fairly close from what I recall
My bronze is 105 mm long after some use. So yes, it's shorter than a stock spring, but also stiffer as you can see from my measurements. Why does everyone get hung up on spring length?
Exactly!! Spring preload, rate, and total force are all the clutch really cares about, free length isn’t something that needs to be considered at all. :dunno:
My stock primary spring wear on the outside of coils. Rubbing? I thougt a shorter spring is better?
Anybody tried the Dalton Black/Red? Thinking it might be a little better for trail than the Black/Bronze.
Why what does it do better, ,,,!! just curious why you guys keep changing springs? Do you ever find the right one and just ride, just curious!? Is the more you monkey the more you can syndrome? Knapp seems to be the man gett’er set and run kinda guy,
