What about using an old cell phone plug in DC adaptor for charging you cell phone and solding on the end plug for the heated shield. It coils up nice and most everyone has an old one lying around.
Soldier'spapa
- Mar 21, 2006
- Naperville, IL
- 2018 Sidewinder Ltx LE 50th Anniversary
Should work just fine.
gsxr
- Feb 24, 2006
- BRACEBRIDGE , ONTARIO
- 2023 SRX
kimpex and other suppliers make it already with the proper plug for the shield , you will have to bump the fuse to a 10amp.
Soldier'spapa
- Mar 21, 2006
- Naperville, IL
Good point about the fuse. I think the fuse in a cell charger is pretty small.... only 3 amps or so. May not be enough for the shield.
06attaker
DC electrical outlet for shield
Go to SMARTRECPARTS.com and type in part number 621200 and they are $6.26. It is well worth the money. There's no picture but its a pretty good adapter for the price.
T-Bone
go to www.westmarine.com and search on part # SC107LED. Great quality and waterproof too.
06attaker
The one from smartrecparts is an actual plug that plugs into the receptacle on your apex and converts it to the heated shield outlet. This is what you are looking for. The west marine is the receptacle and a plug???
FOR SALE: NEW APEX GT SKIS
According to the Yamaha manual the DC adaptor used
a 3Amp Fuse fot the circut.
CaptCaper
- Jan 1, 2007
- Northern N.H.
I got a Yami one and has worked fine..some past posts said they didn't like it and had troubles.
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
if you ride anything but smooth trails...I'd do what I've done...wire directly to the battery with an inline fuse close to the power tap
T-Bone
06attaker said:The one from smartrecparts is an actual plug that plugs into the receptacle on your apex and converts it to the heated shield outlet. This is what you are looking for. The west marine is the receptacle and a plug???
You can buy just the plug. i think it was 6.99. Cut the end off your cord to your helmet and wire up the new plug. 2500 miles not one issue. There are lots of options.
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
do a search...most that run a heated cord off the accessory outlet..blow fuses...it will happen sooner or later...
- 7K
