does anyone know of an adaptor that will go in the 12v port on the 07 attak gt and allow a heated shield to be pluged in directly?
NY AttakGT
Heated shield adapter
If not available through a manufacturer or dealer, I'm sure one can be easily made with a standard cigarette lighter plug (with a 12v output. Most of the time these are fused inside the plug, so make sure to fuse it at the appropriate amperage for your heated shield) and a short length of twin lead wire with a female RCA type connector on the end. One end of the twin-lead soldered to the cig lighter plug and the other end of the twin-lead soldered to the female RCA jack. That along with some heat shrink tubing to keep things neat. Should cost about $10 for all the parts and about 10-15 minutes to make. All the parts should be available at Radio Shack or similar type of electronics hobby store. Just a thought. Not a bad idea though.
--Steve O.C.
--Steve O.C.
watersuper
This link is all you need to do it the easy way.
http://www.yamaha-motor.com/sport/appar ... etail.aspx
blue er
You can buy the plug from yammy, but i just spliced into the socket harness under the panel so i can use my shield and keep my phone/gps units on charge
SRX Rocket
Talk to Kevin from Port Yamaha he has a 12V plug with a pig tail off it for your heated shield, he got me mine.
Jeff
Jeff
radta7
watersuper said:This link is all you need to do it the easy way.
Perfect!!!!! Thanks a ton!!!
RSVECTORGT2006
I was just looking for a 12 volt DC plug in for heated visors in the JR GRAHAM cat log and found for $6.95. Plug in with pig tail& LED indicator light.
Wartsnuff
RSVECTORGT2006 said:I was just looking for a 12 volt DC plug in for heated visors in the JR GRAHAM cat log and found for $6.95. Plug in with pig tail& LED indicator light.
or make your own for about 2-3 bucks from CT
just 0.02 cents
cheers
