Deftonesman
- Dec 10, 2014
- 2013 yamaha Nytro XTX 1.75
I'm looking at buying this outlet plug:
http://www.yamaha-motor.ca/pna/deta...up=SM&unitYear=2013&items_per_page=all&page=1
My concern is where does it connect. I found on the left side of the sled just above the primary cluth, i see a 2 prong plug with seems to be a cover. I'm wondering if this is where this would plug on?
Also would I need to add a fuse to my fusebox to install this? Where can I find technical instructions to add this to my seld?
R00STER
- Mar 3, 2013
- Timmins, Ontario
- 2013 Nytro xtx 1.75
Sounds like you found the correct plug. You take off the protector, plug in the outlet and you are done. It is all ready powered up and waiting.
Deftonesman
- Dec 10, 2014
Yah eh! Ok i will give it a shot. 80$ order it here in canada, wanted to make sure i wasnt wasting
poor farmer/logger
- Dec 3, 2012
- Saskatchewan
Just go and order a sumitomo sealed MT 090 plug online. You can get them for around 3-4 dollars plush shipping. Put it on your own 12 volt outlet and you're done. Total spent probable around 20-30 dollars. There are two types so make sure if you order you order the correct one.
RSVECTORFREAK
- Oct 28, 2004
- Chassell Michigan
- 2005 RS Vector ER
I bought one from a parted grizzly on ebay for $5 shipped! Plug and play!
Tyloooor
holy smokes i've been looking for those plugs forever....broke the clip on my fuel pump connection.....thanks a million!Just go and order a sumitomo sealed MT 090 plug online. You can get them for around 3-4 dollars plush shipping. Put it on your own 12 volt outlet and you're done. Total spent probable around 20-30 dollars. There are two types so make sure if you order you order the correct one.
