the skis will fit. had a set like that on my xtx last season when brother took it trail breaking for 80km one way lol. you have to use the 2009 apex mtx mounting hardware as they use 2 spacers and a longer tube in the bottom of the spindle as well as a longer bolt. re-use stock rubber. you can use washers and a longer bolt if you like but we have found that a good rock hit will break the bolt and leave you on the side of the trail. most of the other hardware I stole from a set of 05 saddless stock skis as the carbides, carbide mounts and ski loops are the same when I did my brothers 2013 rs venture gt conversion to mountain skis last winter. made a huge improvement in handling on that sled. never rode mine with them on as I usually run curves that are pretty close to the same in performance.
